1. Prerequisite
This document describes the software requirements for building RMM for AArch64 target platforms.
It may possible to build RMM with combinations of software packages that are different from those listed below, however only the software described in this document can be officially supported.
2. Build Host
The RMM officially supports a limited set of build environments and setups. In this context, official support means that the environments listed below are actively used by team members and active developers, hence users should be able to recreate the same configurations by following the instructions described below. In case of problems, the RMM team provides support only for these environments, but building in other environments can still be possible.
We recommend at least Ubuntu 20.04 LTS (x64) for build environment. The arm64/AArch64 Ubuntu and other Linux distributions should also work fine, provided that the necessary tools and libraries can be installed.
3. Tool & Dependency overview
The following tools are required to obtain and build RMM:
Name |
Version |
Component |
C compiler |
see Setup Toolchain |
Firmware |
CMake |
>=3.20.0 |
Firmware, Documentation |
GNU Make |
>4.0 |
Python |
3.x |
Perl |
>=5.26 |
ninja-build |
Firmware (using Ninja Generator) |
Sphinx |
>=2.4,<3.0.0 |
Documentation |
sphinxcontrib-plantuml |
Documentation |
sphinx-rtd-theme |
Documentation |
Git |
Graphviz dot |
>v2.38.0 |
Documentation |
docutils |
>v2.38.0 |
Documentation |
gcovr |
>=v4.2 |
Tools(Coverage analysis) |
CBMC |
>=5.84.0 |
Tools(CBMC analysis) |
Cppcheck |
>=2.18.0 |
Tools(Cppcheck) |
pyelftools |
==0.32 |
Firmware (EL0 app) |
Clang-tidy |
>=18.1.8 |
Tools(clang-tidy) |
4. Setup Toolchain
To compile RMM code for an AArch64 target, at least one of the supported AArch64 toolchains have to be available in the build environment.
Currently, the following compilers are supported:
GCC (aarch64-none-elf-) >= 13.3 (from the Arm GNU Toolchain downloads)
Clang+LLVM >= 18.1.0 (from the LLVM Releases website)
The respective compiler binary must be found in the shell’s search path.
Be sure to add the bin/ directory if you have downloaded a binary version.
The toolchain to use can be set using RMM_TOOLCHAIN parameter and can
be set to either llvm or gnu. The default toolchain is gnu.
For non-native AArch64 target build, the CROSS_COMPILE environment
variable must contain the right target triplet corresponding to the AArch64
GCC compiler. Below is an example when RMM is to be built for AArch64 target
on a non-native host machine and using GCC as the toolchain.
export CROSS_COMPILE=aarch64-none-elf- export PATH=<path-to-aarch64-gcc>/bin:$PATH
Please note that AArch64 GCC must be included in the shell’s search path even when using Clang as the compiler as LLVM does not include some C standard headers like stdlib.h and needs to be picked up from the include folder of the AArch64 GCC. Below is an example when RMM is to be built for AArch64 target on a non-native host machine and using LLVM as the toolchain.
export CROSS_COMPILE=aarch64-none-elf- export PATH=<path-to-aarch64-gcc>/bin:<path-to-clang+llvm>/bin:$PATH
The CROSS_COMPILE variable is ignored for fake_host build and
the native host toolchain is used for the build.
5. Package Installation (Ubuntu-20.04 x64)
If you are using the recommended Ubuntu distribution then we can install the required packages with the following commands:
Install dependencies:
sudo apt-get install -y git build-essential python3 python3-pip make ninja-build
sudo snap install cmake
Verify cmake version:
cmake --version
Please download cmake 3.20 or later version from https://cmake.org/download/.
Add CMake path into environment:
export PATH=<CMake path>/bin:$PATH
6. Install python dependencies
RMM’s requirements.txt file declares additional Python dependencies.
Install them with pip3:
pip3 install --upgrade pip
cd <rmm source folder>
pip3 install -r requirements.txt
7. Install python dependencies for Documentation
The installation of Python dependencies for documentation is an optional step. This is required only if building documentation.
RMM’s docs/requirements.txt file declares additional Python dependencies.
pip3 install -r docs/requirements.txt
8. Install coverage tools analysis dependencies
This is an optional step only needed if you intend to run coverage analysis on the source code.
On Ubuntu, gcovr tool can be installed in two different ways:
Using the package manager:
sudo apt-get install gcovr
The second (and recommended) way is install it with pip3:
pip3 install gcovr
9. Getting the RMM Source
Source code for RMM is maintained in a Git repository hosted on TrustedFirmware.org. To clone this repository from the server, run the following in your shell:
git clone https://git.trustedfirmware.org/TF-RMM/tf-rmm.git
Note that the RMM submodule dependencies will be updated during the configuration phase of build.
9.1. Additional steps for Contributors
If you are planning on contributing back to RMM, your commits need to
include a Change-Id footer as explained in Mandated Trailers.
This footer is generated by a Git hook that needs to be installed
inside your cloned RMM source folder.
The TF-RMM Gerrit page under trustedfirmware.org contains a Clone with commit-msg hook subsection under its Download header where you can copy the command to clone the repo with the required git hooks. Please use the SSH option to clone the repository on your local machine.
If needed, you can also manually install the hooks separately on an existing repo:
curl -Lo $(git rev-parse --git-dir)/hooks/commit-msg https://review.trustedfirmware.org/tools/hooks/commit-msg
chmod +x $(git rev-parse --git-dir)/hooks/commit-msg
You can read more about Git hooks in the githooks page of the Git hooks documentation.
General contribution guidelines for contributors can be found in Contributor’s Guide.
10. Install Cppcheck and dependencies
The installation of Cppcheck is an optional step. This is required only if using the Cppcheck static analysis.
The recommended version of Cppcheck is indicated in Tool & Dependency overview. See Cppcheck Application Note for installation steps and details on how to use it within RMM build system.
11. Install CBMC
The installation of CBMC is an optional step. This is required only if running source code analysis with CBMC.
Follow the public documentation to install CBMC either from the official website https://www.cprover.org/cbmc/ or from the official github https://github.com/diffblue/cbmc
Refer to CBMC Application Notes for details on installation and running CBMC analysis on TF-RMM sources.
12. Install Clang-tidy
Clang-tidy is included in LLVM release package. It can also be installed via package manager :
sudo apt-get install clang-tidy
Note that the RMM_TOOLCHAIN needs to be set to llvm to run clang-tidy
build targets from RMM build system.
13. Performing an Initial Build
The RMM sources can be compiled using multiple CMake options.
For detailed instructions on build configurations and examples see RMM Build Examples.
A typical build command for the FVP platform using GCC toolchain is shown below:
cmake -DRMM_CONFIG=fvp_defcfg -S ${RMM_SOURCE_DIR} -B ${RMM_BUILD_DIR}
cmake --build ${RMM_BUILD_DIR}
14. Running the RMM
The RMM is part of the CCA software stack and relies on EL3 Firmware to load the binary at boot time appropriately. It needs both EL3 Firmware and Non-Secure Host to be present at runtime for its functionality. The EL3 Firmware must comply to RMM-EL3 Communication Specification and is typically the TF-A. The Non-Secure Host can be an RME aware hypervisor or an appropriate Test utility running in Non-Secure world which can interact with RMM via Realm Management Interface (RMI).
Building all of the involved stack is complicated. We recommend using the Shrinkwrap tooling to bootstrap the stack. For more details on Shrinkwrap and utilizing configs and overlays included in RMM please refer to Building with Shrinkwrap and, specially for building a demonstrator for 3-world, you can refer to 3-World testing.
The TF-A documentation also provides some documentation to build TF-A and
other pieces of firmware for RME in TF-A RME documentation. The RMM build
option in TF-A should point to the rmm.img binary generated by building
RMM.
If RMM is built for the fake_host architecture (see RMM Fake Host Build), then the generated rmm_core.elf binary can run natively on the Host machine. It does this by emulating parts of the system as described in RMM Fake host architecture design.
