1.4. Threat Assessment
The following threats were identified by applying STRIDE analysis on each diagram element of the data flow diagram. The threats are related to software and implementation specific to TF-RMM.
For each threat, we strive to indicate whether the mitigations are currently implemented or not. However, the answer to this question is not always straightforward. Some mitigations are partially implemented in the generic code but also rely on the platform code to implement some bits of it. This threat model aims to be platform-independent and it is important to keep in mind that such threats only get mitigated if the platform properly fulfills its responsibilities.
Also, some mitigations might require enabling specific features, which must be explicitly turned on via a build flag.
The Pending actions? box highlights any action that needs to be done in
order to implement the mitigations.
ID |
01 |
Threat |
Information leak via UART logs.
During the development stages of software it is
common to print all sorts of information on the
console, including sensitive or confidential
information such as crash reports with detailed
information of the CPU state, current registers
values, privilege level or stack dumps.
This information is useful when debugging
problems before releasing the production
version but it could be used by an adversary
to develop a working exploit if left enabled in
the production version.
This happens when directly logging sensitive
information and more subtly when logging based
on sensitive data that can be used as a
side-channel information by an adversary.
Diagram Elements |
DF2 |
Assets |
Sensitive Data |
Threat Agent |
AppDebug |
Threat Type |
Information Disclosure |
Informational (1) |
Likelihood |
Informational (1) |
Total Risk Rating |
Informational (1) |
Mitigations |
1) For production releases:
i) Remove sensitive information logging.
ii) Do not conditionally log based on
sensitive data.
iii) Do not log high precision timing
information.
iv) Do not log register contents which may
reveal secrets during crashes (Error
Syndrome registers are allowed to be
logged).
2) Provide option to fully disable RMM logging
for production releases.
Mitigations implemented? |
1) Yes/Platform-specific.
The default log level does not output verbose
log. RMM does not implement crash reporting.
Messages produced by the platform code
should use the appropriate level of verbosity
so as not to leak sensitive information in
production builds.
2) Yes.
RMM provides the
LOG_LEVEL build option
which can be used to disable all logging. |
Pending actions? |
1) Ensure the right verbosity level is used for
the type of information that it is logged.
ID |
02 |
Threat |
An adversary can try stealing information by
using RMM ABI.
NS Host accesses RMM through RMM ABI. Malicious
code can attempt to invoke services that would
result in disclosing private information or
secrets.
Diagram Elements |
DF7 |
Assets |
Sensitive Data |
Threat Agent |
HostSoftware |
Threat Type |
High (4) |
Likelihood |
High (4) |
Total Risk Rating |
High (16) |
Mitigations |
1) Ensure that RMM protects the Realm memory by
using GPT service provided by EL3 Firmware
and appropriate Stage 2 protections. NS Host
must not be able to change or access Realm
memory.
2) NS host must not be able to change or access
Realm CPU register contents other than what
is allowed by RMM ABI. Root code should
perform proper context switching of certain
subset of CPU registers as mandated in
RMM-EL3 Communication Interface when
entering and exiting the Realm world.
Similarly, RMM should context switch any
registers not managed by EL3 when
entering/exiting Realms.
3) The RME Architecture provides means to
configure memory isolation to the Realm
world. RMM relies on Root code for correct
RME setup. But when undelegating memory to
the Normal world, RMM needs to ensure that
suitable memory scrubbing is implemented.
Also, RMM should ensure any architectural
caches are invalidated before returning back
to NS Host.
1) Yes.
2) Yes.
3) Yes.
Pending actions? |
None.
ID |
03 |
Threat |
An adversary can perform a denial-of-service
attack on the system by causing the Realm
world/RMM to deadlock, crash or enter into an
unknown state.
Diagram Elements |
DF5, DF7 |
Assets |
Availability |
Threat Agent |
RealmCode, HostSoftware |
Threat Type |
Denial of Service |
Medium (3) |
Likelihood |
Low (2) |
Total Risk Rating |
Medium (6) |
Mitigations |
1) Upon an unrecoverable/catastrophic condition,
RMM should issue a
panic(). This wouldreturn to EL3 Firmware, keeping the
availability of the overall system. It would
be EL3 responsibility to decide how to
proceed (e.g. by disabling the whole Realm
world).
2) EL3 Firmware needs to implement a watchdog
mechanism to recover CPUs from Realm World.
1) No.
2) Mitigation would need support from EL3
Firmware.
Pending actions? |
panic() needs appropriate implementation to
return to EL3 Firmware. |
ID |
04 |
Threat |
Malicious Host or Realm code can attempt to
place the RMM into an inconsistent state due to
incorrect implementation of RMM state machines.
This inconsistency can be exploited to lead
incorrect operation of RMM.
Diagram Elements |
DF5, DF7 |
Assets |
Availability, Sensitive Data, Code Execution |
Threat Agent |
Threat Type |
Denial of Service, Tampering, Elevation of privilege, Information Disclosure |
Medium (3) |
Likelihood |
Low (2) |
Total Risk Rating |
Medium (6) |
Mitigations |
1) State machines should be tested for all the
transitions and validated that all invalid
transitions and inputs are rejected.
2) The RMM ABI mandates pre and post conditions
for each ABI. The tests should verify that
these conditions are adhered to and
implemented.
3) Static analyzers and model checkers can be
used to uncover bugs in implementation.
4) Fuzz testing can be employed to uncover
further issues in implementation.
5) Upon an unrecoverable/catastrophic condition
occurs, RMM should issue a
panic() toprevent further corruption of data or
propagation of errors.
1) Partial.
There are various tests in TFTF, ACS and
kvm-unit-tests for exercising the ABI which
triggers the state machines. Unit tests are
also present for some components to exercise
internal APIs which can further test
conditions and invalid cases which cannot be
triggered via RMM ABI.
2) Partial.
Code reviews to ensure the implementation
complies the required conditions. Automated
checking via CBMC to validate the same is
also being implemented.
3) Yes.
CPPCheck and Coverity scan are used to detect
issues. CBMC is also utilized as a model
checker.
4) No.
5) Yes.
Pending actions? |
Expand coverage of unittests in RMM. Evolve
tests in other test frameworks in an ongoing
manner. Integrate CBMC into RMM testing.
Implement Fuzz testing for RMM.
ID |
05 |
Threat |
Malicious Host or Realm code can attack RMM by
calling unimplemented SMC calls or by passing
invalid arguments to the ABI.
Diagram Elements |
DF5, DF7 |
Assets |
Threat Agent |
Threat Type |
High (4) |
Likelihood |
High (4) |
Total Risk Rating |
High (16) |
Mitigations |
1) Validate SMC function IDs and arguments
before using them.
2) Invalid/Unimplemented SMCs should return back
to caller with error code.
3) Tests to exercise invalid arguments and
unimplemented SMCs.
1) Yes.
2) Yes.
3) Partial.
The ACS test utility exercises many invalid
inputs. Unit tests also test various invalid
cases.
Pending actions? |
Expand unit tests to cover the RMM ABI interface
and test for invalid inputs.
ID |
06 |
Threat |
An adversary can make use of incorrect
implementation of concurrent sections in RMM to
cause data corruption or dead/live locks.
Diagram Elements |
DF5, DF7 |
Assets |
Threat Agent |
Threat Type |
Medium (3) |
Likelihood |
Low (2) |
Total Risk Rating |
Medium (6) |
Mitigations |
1) Follow locking discipline described in
RMM Locking Guidelines when implementing
concurrent sections in RMM.
2) Validate locking discipline using tests which
can run multiple threads in RMM.
3) Fuzz tests on RMM with multiple threads.
1) Yes.
2) Yes.
The TFX test has tests which can test
concurrent sections in RMM. Also, stress
tests in CI will also test this scenario.
3) No.
Need further investigation.
Pending actions? |
Enhance TFX tests to test more concurrent
sections in RMM. Investigate the possibility of
multithread Fuzz Testing.
ID |
07 |
Threat |
A Realm can claim to be another Realm. NS Host
can associate the PA of one Realm to another
Realm.
Diagram Elements |
DF5, DF7 |
Assets |
Sensitive Data |
Threat Agent |
Threat Type |
Spoofing |
High (4) |
Likelihood |
Low (2) |
Total Risk Rating |
Medium (8) |
Mitigations |
1) A Realm should not be able to spoof another
realm. The NSHost must not be able to assign
a granule/metadata to a Realm which is
already assigned to another Realm.
Mitigations Implemented? |
1) Yes.
This mitigation is inherently supported by
the RMM ABI. SMC call from realm is always
associated to the Realm Descriptor (RD) and
the RMM ABI does not allow spoofing of RD.
NS Host always has to pass the address of a
valid RD to make requests to the
corresponding Realm. RMM maintains a global
granule array and every granule linked to a
Realm has a specific State and reference
count associated with it. Hence, the NS Host
cannot associate an already Realm associated
granule to another Realm.
Pending actions? |
None.
ID |
08 |
Threat |
An adversary could execute arbitrary code,
modify some state variables, change the normal
flow of the program or leak sensitive
information if memory overflows and boundary
checks when accessing resources are not properly
handled. In the particular case in which the
control flow can be changed by a stack overflow,
code execution can also be subverted by an
adversary.
Like in other software, RMM has multiple points
where memory corruption and security errors can
arise.
Some of the errors include integer overflow,
buffer overflow, incorrect array boundary checks
and incorrect error management.
Improper use of asserts instead of proper input
validations might also result in these kinds of
errors in release builds.
Diagram Elements |
DF5, DF7 |
Assets |
Code Execution, Sensitive Data, Availability |
Threat Agent |
Threat Type |
Tampering, Information Disclosure, Elevation of Privilege |
Medium (3) |
Likelihood |
Low (2) |
Total Risk Rating |
Medium (6) |
Mitigations |
1) Use proper input validation.
2) Enable Architecture security features to
mitigate buffer overflow and ROP/JOP issues.
3) Utilize stack protection mechanism provided
by the compiler.
4) Design suitable per CPU stack protection, so
another CPU cannot corrupt stack which does
not belong to it.
5) Suitable testing to test bounds of inputs.
6) Employ secure coding guidelines like MISRA to
remove many of the type safety issues
associated with the C language.
7) Use static analyzers to check for common
issues. Also, make use of model checkers to
validate loop bounds and other bounds in the
source code.
1) Yes.
2) Yes.
RMM Enables many Architecture security
features like PAuth and BTI but there is
ongoing action to enable more architectural
security features.
3) No.
4) No.
5) Partial.
Some tests are present, but more tests needed
to ensure the bounds are validated.
6) Yes.
7) Partial.
RMM uses CPPCheck and Coverity Scan to detect
issues. RMM also utilizes CMBC to ensure that
bounds in loops and other program constructs
are proper.
Pending actions? |
Add sanitizers like ASAN, MSAN or UBSAN.
Implement further Architecture extensions
related to security. RMM needs to implement
per-CPU stack protection and also provide
capability to add compiler stack protection
features as a user option.
ID |
09 |
Threat |
SMC calls can leak sensitive information from
RMM memory via microarchitectural side channels.
Microarchitectural side-channel attacks such as
Spectre can be used to leak data across
security boundaries. An adversary might attempt
to use this kind of attack to leak sensitive
data from RMM memory.
Also, some SMC calls, such as the ones involving
encryption when applicable, might take different
amount of time to complete depending upon the
parameters. An adversary might attempt to use
that information in order to infer secrets or to
leak sensitive information.
Diagram Elements |
DF5, DF7 |
Assets |
Sensitive Data |
Threat Agent |
Threat Type |
Medium (3) |
Likelihood |
Informational (1) |
Total Risk Rating |
Low (3) |
Mitigations |
1) Enable appropriate speculation side-channel
mitigations as recommended by the
Architecture.
2) Enable appropriate timing side-channel
protections available in the Architecture.
3) Ensure the software components dealing with
sensitive data use Data Independent
algorithms.
4) Ensure that only required memory is mapped
when executing a Realm or doing operations in
RMM so as to minimize effects of CPU
speculation.
1) Yes.
2) Yes.
FEAT_DIT is enabled for RMM during
attestation initialization and token signing
phase.3) Yes.
RMM relies on MbedTLS library to use
algorithms which are data independent when
handling sensitive data.
4) Yes.
The slot buffer design for dynamically
mapping memory ensures that only required
memory is mapped into RMM.
Pending actions? |
Review speculation vulnerabilities and ensure
RMM implements all mitigations provided by the
Architecture.
ID |
10 |
Threat |
Misconfiguration of the S2 MMU tables may allow
Realms to access sensitive data belonging to
other Realms or incorrect mapping of NS memory
may allow Realms to corrupt NSHost memory.
Diagram Elements |
DF5, DF7 |
Assets |
Sensitive Data, Code execution |
Threat Agent |
Threat Type |
High (4) |
Likelihood |
Low (2) |
Total Risk Rating |
Medium (8) |
Mitigations |
1) Ensure proper implementation of S2 table
management code in RMM. It should not be
possible to trigger misconfiguration of S2
tables using RMM ABI. Appropriate tests to
ensure that the implementation is robust.
2) The RMM specification mandates the rules for
assigning memory to a Realm and IPA
management. Ensure the rules mandated by the
RMM specification are validated by suitable
tooling.
1) Partially.
There are various tests like kvm-unit-tests,
TFTF, TFX and ACS to test the
implementation. Unit tests of S2 tables need
to be implemented. Static analysis is in
place to detect issues.
2) Partially.
complies with the required conditions.
Automated checking via CBMC to validate the
same is also being implemented.
Pending actions? |
Increase testing coverage of S2 table management
code in RMM.
Integrate CMBC into RMM testing.
ID |
11 |
Threat |
Realm code flow diversion through REC metadata
manipulation from Host Software.
An adversary with access to a Realm’s REC could
tamper with the structure content and affect the
Realm’s execution flow.
Diagram Elements |
DF7 |
Assets |
Code Execution |
Threat Agent |
HostSoftware |
Threat Type |
Tampering |
High (4) |
Likelihood |
Low (2) |
Total Risk Rating |
Medium (8) |
Mitigations |
1) The RMM specification mandates that sensitive
metadata like REC should be stored in Realm
PAS. Also, the specification does not allow
NSHost to manipulate REC contents via RMI
once the associated Realm is Activated.
Ensure that the RMM specification guidelines
are enforced.
2) Map sensitive metadata into RMM S1 tables
only when manipulating the Realm/REC. Once
RMM is finished manipulating the metadata,
unmap it from S1 tables. Thus the time window
when RMM can access the metadata is kept to a
minimum thus reducing the opportunity to
corrupt the metadata.
1) Yes.
2) Yes.
The slot-buffer mechanism in RMM is used to
map metadata only when needed and it is
unmapped when the access is not required.
Pending actions? |
None |
ID |
12 |
Threat |
Use of PMU and MPAM statistics to increase the
the accuracy of side channel attacks.
Diagram Elements |
DF5, DF7 |
Assets |
Sensitive Data |
Threat Agent |
Threat Type |
Medium (3) |
Likelihood |
Informational (1) |
Total Risk Rating |
Low (3) |
Mitigations |
1) Save/Restore performance counters on
on transitions between security domains or
between Realms.
2) Configure MPAM so that is either disabled or
set to default values for Realm world.
1) PMU is saved and restored.
2) MPAM is not enabled for Realm world.
Pending actions? |
None. |
ID |
13 |
Threat |
Misconfiguration of the hardware IPs and
registers may lead to data leaks or incorrect
behaviour that could be damaging on its own as
well as being exploited by a threatening agent.
RMM needs to interact with several hardware IPs
as well as system registers for which it uses
its own libraries and/or drivers.
Misconfiguration of such elements could cause
data leaks and/or system malfunction.
Diagram Elements |
DF5, DF7 |
Assets |
Threat Agent |
Threat Type |
Information Disclosure, Denial of Service |
High (4) |
Likelihood |
Low (2) |
Total Risk Rating |
Medium (8) |
Mitigations |
1) Code reviews.
2) Testing on FVPs and other hardware and
emulation platforms to check for correct
behaviour.
1) Yes.
2) Yes.
RMM is tested regularly on FVP and more
platforms will be added in future as they
become available.
Pending actions? |
None |
