15. RMM Build Examples
The RMM supports a wide range of build configuration options. Some of these options are more regularly exercised by developers, while others are for advanced and experimental usage only.
RMM can be built using either GNU(GCC) or LLVM(Clang) toolchain. See this section for toolchain setup and the supported versions.
The build is performed in 2 stages:
Configure Stage: In this stage, a default config file can be specified which configures a sane config for the chosen platform. If this default config needs to be modified, it is recommended to first perform a default config and then modify using the cmake ncurses as shown in CMake UI Example.
Build Stage: In this stage, the source build is performed by specifying the –build option. See any of the commands below for an example.
It is recommended to clean build if any of the build options are changed from previous build.
Below are some of the typical build and configuration examples frequently used in RMM development for the FVP Platform. Detailed configuration options are described here.
RMM also supports a fake_host build which can be used to build RMM for test
and code analysis on the host machine. See
this section here for more details.
Perform an initial default build with minimum configuration options:
Build using gnu toolchain
cmake -DRMM_CONFIG=fvp_defcfg -S ${RMM_SOURCE_DIR} -B ${RMM_BUILD_DIR}
cmake --build ${RMM_BUILD_DIR}
Build using LLVM toolchain
cmake -DRMM_CONFIG=fvp_defcfg -DRMM_TOOLCHAIN=llvm -S ${RMM_SOURCE_DIR} -B ${RMM_BUILD_DIR}
Perform an initial default config, then modify using ccmake ncurses UI:
ccmake -S ${RMM_SOURCE_DIR} -B ${RMM_BUILD_DIR}
Perform a debug build and specify a log level:
cmake -DRMM_CONFIG=fvp_defcfg -S ${RMM_SOURCE_DIR} -B ${RMM_BUILD_DIR} -DCMAKE_BUILD_TYPE=Debug -DLOG_LEVEL=50
Perform a documentation build:
cmake -DRMM_CONFIG=fvp_defcfg -S ${RMM_SOURCE_DIR} -B ${RMM_BUILD_DIR} -DRMM_DOCS=ON
cmake --build ${RMM_BUILD_DIR} -- docs
Perform a clean verbose build:
cmake --build ${RMM_BUILD_DIR} --clean-first --verbose
Perform a build with Ninja Genenerator:
cmake -DRMM_CONFIG=fvp_defcfg -S ${RMM_SOURCE_DIR} -B ${RMM_BUILD_DIR} -DCMAKE_BUILD_TYPE=${BUILD_TYPE} -G "Ninja" -DLOG_LEVEL=50
Perform a build with Ninja Multi Config Genenerator:
cmake -DRMM_CONFIG=fvp_defcfg -S ${RMM_SOURCE_DIR} -B ${RMM_BUILD_DIR} -G "Ninja Multi-Config" -DLOG_LEVEL=50
cmake --build ${RMM_BUILD_DIR} --config ${BUILD_TYPE}
Perform a Cppcheck static analysis:
Refer to Cppcheck Application Note for details on installing and running cppcheck static analysis.
cmake -DRMM_CONFIG=fvp_defcfg -DCMAKE_EXPORT_COMPILE_COMMANDS=ON -S ${RMM_SOURCE_DIR} -B ${RMM_BUILD_DIR}
cmake --build ${RMM_BUILD_DIR} -- cppcheck
cat ${RMM_BUILD_DIR}/tools/cppcheck/cppcheck.xml
Perform a Cppcheck static analysis with MISRA:
cmake --build ${RMM_BUILD_DIR} -- cppcheck-misra
cat ${RMM_BUILD_DIR}/tools/cppcheck/cppcheck_misra.xml
Perform a checkpatch analysis:
Run checkpatch on commits in the current branch against BASE_COMMIT (default origin/main):
cmake --build ${RMM_BUILD_DIR} -- checkpatch
Run checkpatch on entire codebase:
cmake --build ${RMM_BUILD_DIR} -- checkcodebase
Perform a checkspdx analysis:
Run checkspdx on commits in the current branch against BASE_COMMIT (default origin/main):
cmake --build ${RMM_BUILD_DIR} -- checkspdx-patch
Run checkspdx on entire codebase:
cmake --build ${RMM_BUILD_DIR} -- checkspdx-codebase
Check header file include order:
Run checkincludes-patch on commits in the current branch against BASE_COMMIT (default origin/main):
cmake --build ${RMM_BUILD_DIR} -- checkincludes-patch
Run checkincludes on entire codebase:
cmake --build ${RMM_BUILD_DIR} -- checkincludes-codebase
Perform a clang-tidy analysis:
Run clang-tidy on commits in the current branch against BASE_COMMIT (default origin/main):
cmake -DRMM_CONFIG=fvp_defcfg -DRMM_TOOLCHAIN=llvm -DCMAKE_EXPORT_COMPILE_COMMANDS=ON -S ${RMM_SOURCE_DIR} -B ${RMM_BUILD_DIR}
cmake --build ${RMM_BUILD_DIR} -- clang-tidy-patch
Run clang-tidy on entire codebase:
cmake --build ${RMM_BUILD_DIR} -- clang-tidy-codebase
Note that clang-tidy will work with all configurations. It will only check the source files that are used for the specified configuration.
Perform a checkbannedapi analysis:
Run checkbannedapi on commits in the current branch against BASE_COMMIT (default origin/main):
cmake --build ${RMM_BUILD_DIR} -- checkbannedapi-patch
Run checkbannedapi on entire codebase:
cmake --build ${RMM_BUILD_DIR} -- checkbannedapi-codebase
Perform unit tests on development host:
Build and run unit tests on host platform. It is recommended to enable the Debug build of RMM.
cmake -DRMM_CONFIG=host_defcfg -DHOST_VARIANT=host_test -DCMAKE_BUILD_TYPE=Debug -S ${RMM_SOURCE_DIR} -B ${RMM_BUILD_DIR}
cmake --build ${RMM_BUILD_DIR} -- run-unittests
Run unittests for a specific test group(s) (e.g. unittests whose group starts with ‘xlat’)
cmake --build ${RMM_BUILD_DIR} -- build -j
${RMM_BUILD_DIR}/Debug/rmm_core.elf -gxlat -v -r${NUMBER_OF_TEST_ITERATIONS}
Generate Coverage Report.
It is possible to generate a coverage report for a last execution of the host platform (whichever the variant) by using the run-coverage build target.
For example, to generate coverate report on the whole set of unittests:
cmake -DRMM_CONFIG=host_defcfg -DHOST_VARIANT=host_test -DRMM_COVERAGE=ON -DCMAKE_BUILD_TYPE=Debug -S ${RMM_SOURCE_DIR} -B ${RMM_BUILD_DIR}
cmake --build ${RMM_BUILD_DIR} -- run-coverage
Run coverage analysis on a specific set of unittests (e.g. unittests whose group starts with ‘xlat’)
Run coverage analysis on the host_build variant of host platform:
cmake -DRMM_CONFIG=host_defcfg -DHOST_VARIANT=host_build -DRMM_COVERAGE=ON -DCMAKE_BUILD_TYPE=Debug -S ${RMM_SOURCE_DIR} -B ${RMM_BUILD_DIR}
The above commands will automatically generate the HTML coverage report in folder build/Debug/coverage within the build directory. The HTML generation can be disabled by setting RMM_HTML_COV_REPORT=OFF.
Run CBMC analysis:
Run COVERAGE, ANALYSIS and ASSERT targets for CBMC. The results
are generated in ${RMM_BUILD_DIR}/tools/cbmc/cbmc_coverage_results.
cmake -DRMM_CONFIG=host_defcfg -DHOST_VARIANT=host_cbmc -S ${RMM_SOURCE_DIR} -B ${RMM_BUILD_DIR}
cmake --build ${RMM_BUILD_DIR} -- cbmc-coverage cbmc-analysis cbmc-assert
Refer to CBMC Application Note for details on installing and running CBMC.
16. RMM Build Options
The RMM build system supports the following CMake build options.
Option |
Valid values |
Default |
Description |
RMM_CONFIG |
Platform build configuration, eg: fvp_defcfg for the FVP |
RMM_ARCH |
aarch64 | fake_host |
aarch64 |
Target Architecture for RMM build |
RMM_MAX_SIZE |
0x0 |
Maximum size for RMM image |
MAX_CPUS |
16 |
Maximum number of CPUs supported by RMM |
GRANULE_SHIFT |
12 |
Granule Shift used by RMM |
RMM_CCA_TOKEN_BUFFER |
1 |
Number of pages to allocate in Aux granules for Realm CCA token |
RMM_DOCS |
ON | OFF |
OFF |
RMM Documentation build |
CMAKE_BUILD_TYPE |
Debug | Release |
Release |
CMake Build type |
CMAKE_CONFIGURATION_TYPES |
Debug & Release |
Debug & Release |
Multi-generator configuration types |
CMAKE_DEFAULT_BUILD_TYPE |
Debug | Release |
Release |
Default multi-generator configuration type |
RMM_PLATFORM |
fvp | host |
Platform to build |
RMM_TOOLCHAIN |
gnu | llvm |
Toolchain name |
LOG_LEVEL |
0 - 50 |
40(Debug) 20(Release) |
Log level to apply for RMM (0 - 50). |
RMM_STATIC_ANALYSIS |
Enable static analysis checkers |
PL011_GENERIC_SBSA_UART |
ON | OFF |
OFF |
Enable Generic (SBSA Compliant) PL011. This a subset of PL011 UART |
PL011_HW_FLOW_CONTROL |
ON | OFF |
OFF |
Enable HW flow control for PL011 UART |
PLAT_CMN_VIRT_ADDR_SPACE_WIDTH |
38 |
Stage 1 Virtual address space width in bits for this platform |
RMM_NUM_PAGES_PER_STACK |
5 |
Number of pages to use per CPU stack |
MBEDTLS_ECP_MAX_OPS |
248 - |
1000 |
Number of max operations per ECC signing iteration |
DOWNREV_CCA_TOKEN_TOP_FORMAT |
TRUE | FALSE |
FALSE |
Enables support for the (deprecated) EAT Collection form of the CCA top level attestation token |
RMM_FPU_USE_AT_REL2 |
ON | OFF |
OFF(fake_host) ON(aarch64) |
Enable FPU/SIMD usage in RMM. |
HOST_VARIANT |
host_build | host_test | host_cbmc | host_fuzz |
host_build |
Variant to build for the host platform. Only available when RMM_PLATFORM=host |
HOST_DRAM_SIZE |
0x20000000 |
Host memory size that will be used as physical DRAM |
HOST_NCOH_DEV_SIZE |
0xA000 |
Host memory size that will be used as non-coherent device granules |
RMM_COVERAGE |
ON | OFF |
OFF |
Enable coverage analysis |
RMM_HTML_COV_REPORT |
ON | OFF |
ON |
Enable HTML output report for coverage analysis |
RMM_CBMC_VIEWER_OUTPUT |
ON | OFF |
OFF |
Generate report of CBMC results using the tool cbmc-viewer |
RMM_CBMC_SINGLE_TESTBENCH |
OFF |
Run CBMC on a single testbench instead on all of them |
RMM_EL3_COMPAT_RESERVE_MEM |
ON | OFF |
ON |
Enable compatibility for reserve memory capability from EL3. |
RMM_MEM_SCRUB_METHOD |
0 - 2 |
0 |
Memory Scrub method selection when granule are returned to NS Host. |
RMM_ALLOC_TRACKING_DATA |
ON | OFF |
ON |
Preallocate the fine granule arrays from EL3 during RMM boot. |
RMM_VA_POOL_SIZE |
0x40000000 |
Size of the dynamic virtual address pool |
ATTEST_PLAT_TOKEN_SIZE |
0x1000 |
Maximum size in bytes expected for the Attestation platform token |
PLAT_ARM_MAX_MEM_BANKS |
2 |
Maximum possible number of DRAM and COH/NCOH device memory banks allowed in Arm platform layer |
ATTEST_EL3_TOKEN_SIGN |
ON|OFF |
OFF |
Use EL3 service to sign realm attestation token. |
STACK_PROTECTOR |
ON | OFF |
OFF |
Enable the stack protector compiler option. |
UBSAN |
ON | OFF |
OFF |
Enable Undefined Behavior Sanitizer. Deprecated: use RMM_SANITIZERS instead. |
RMM_SANITIZERS |
ALL | UBSAN | IOSAN | ICSAN | LBSAN | NGSAN |
Sanitizers to enable for the build. ALL enables all sanitizers. IOSAN, ICSAN, LBSAN and NGSAN are LLVM-only. |
The below options are deprecated and only available when RMM_EL3_COMPAT_RESERVE_MEM is enabled.
Option |
Valid values |
Default |
Description |
RMM_MAX_GRANULES |
0 |
Maximum number of memory granules available to the system |
RMM_MAX_COH_GRANULES |
1 |
Maximum number of coherent device granules available to the system |
RMM_MAX_NCOH_GRANULES |
1 |
Maximum number of non-coherent device granules available to the system |
PLAT_CMN_CTX_MAX_XLAT_TABLES |
0 |
Maximum number of translation tables used by the runtime context |
17. RMM LLVM Build
RMM can be built using LLVM Toolchain (Clang). To build using LLVM toolchain, set RMM_TOOLCHAIN=llvm during configuration stage.
18. RMM Fake Host Build
RMM also provides a fake_host target architecture which allows the code to
be built natively on the host using the host toolchain. To build for
fake_host architecture, set RMM_CONFIG=host_defcfg during the
