.. SPDX-License-Identifier: BSD-3-Clause .. SPDX-FileCopyrightText: Copyright TF-RMM Contributors. .. _build_options_examples: ##################### RMM Build Examples ##################### The |RMM| supports a wide range of build configuration options. Some of these options are more regularly exercised by developers, while others are for **advanced** and **experimental** usage only. |RMM| can be built using either GNU(GCC) or :ref:`LLVM(Clang)` toolchain. See :ref:`this section` for toolchain setup and the supported versions. The build is performed in 2 stages: **Configure Stage:** In this stage, a default config file can be specified which configures a sane config for the chosen platform. If this default config needs to be modified, it is recommended to first perform a default config and then modify using the cmake ncurses as shown in :ref:`CMake UI Example`. **Build Stage:** In this stage, the source build is performed by specifying the `--build` option. See any of the commands below for an example. .. note:: It is recommended to clean build if any of the build options are changed from previous build. Below are some of the typical build and configuration examples frequently used in |RMM| development for the FVP Platform. Detailed configuration options are described :ref:`here`. RMM also supports a ``fake_host`` build which can be used to build RMM for test and code analysis on the host machine. See :ref:`this section here` for more details. 1. Perform an initial default build with minimum configuration options: Build using gnu toolchain .. code-block:: bash cmake -DRMM_CONFIG=fvp_defcfg -S ${RMM_SOURCE_DIR} -B ${RMM_BUILD_DIR} cmake --build ${RMM_BUILD_DIR} Build using LLVM toolchain .. code-block:: bash cmake -DRMM_CONFIG=fvp_defcfg -DRMM_TOOLCHAIN=llvm -S ${RMM_SOURCE_DIR} -B ${RMM_BUILD_DIR} cmake --build ${RMM_BUILD_DIR} .. _build_config_example: 2. Perform an initial default config, then modify using ccmake ncurses UI: .. code-block:: bash cmake -DRMM_CONFIG=fvp_defcfg -S ${RMM_SOURCE_DIR} -B ${RMM_BUILD_DIR} ccmake -S ${RMM_SOURCE_DIR} -B ${RMM_BUILD_DIR} cmake --build ${RMM_BUILD_DIR} 3. Perform a debug build and specify a log level: .. code-block:: bash cmake -DRMM_CONFIG=fvp_defcfg -S ${RMM_SOURCE_DIR} -B ${RMM_BUILD_DIR} -DCMAKE_BUILD_TYPE=Debug -DLOG_LEVEL=50 cmake --build ${RMM_BUILD_DIR} 4. Perform a documentation build: .. code-block:: bash cmake -DRMM_CONFIG=fvp_defcfg -S ${RMM_SOURCE_DIR} -B ${RMM_BUILD_DIR} -DRMM_DOCS=ON cmake --build ${RMM_BUILD_DIR} -- docs 5. Perform a clean verbose build: .. code-block:: bash cmake -DRMM_CONFIG=fvp_defcfg -S ${RMM_SOURCE_DIR} -B ${RMM_BUILD_DIR} cmake --build ${RMM_BUILD_DIR} --clean-first --verbose 6. Perform a build with Ninja Genenerator: .. code-block:: bash cmake -DRMM_CONFIG=fvp_defcfg -S ${RMM_SOURCE_DIR} -B ${RMM_BUILD_DIR} -DCMAKE_BUILD_TYPE=${BUILD_TYPE} -G "Ninja" -DLOG_LEVEL=50 cmake --build ${RMM_BUILD_DIR} 7. Perform a build with Ninja Multi Config Genenerator: .. code-block:: bash cmake -DRMM_CONFIG=fvp_defcfg -S ${RMM_SOURCE_DIR} -B ${RMM_BUILD_DIR} -G "Ninja Multi-Config" -DLOG_LEVEL=50 cmake --build ${RMM_BUILD_DIR} --config ${BUILD_TYPE} 8. Perform a Cppcheck static analysis: Refer to :ref:`Cppcheck Application Note` for details on installing and running cppcheck static analysis. .. code-block:: bash cmake -DRMM_CONFIG=fvp_defcfg -DCMAKE_EXPORT_COMPILE_COMMANDS=ON -S ${RMM_SOURCE_DIR} -B ${RMM_BUILD_DIR} cmake --build ${RMM_BUILD_DIR} -- cppcheck cat ${RMM_BUILD_DIR}/tools/cppcheck/cppcheck.xml 9. Perform a Cppcheck static analysis with MISRA: Refer to :ref:`Cppcheck Application Note` for details on installing and running cppcheck static analysis. .. code-block:: bash cmake -DRMM_CONFIG=fvp_defcfg -DCMAKE_EXPORT_COMPILE_COMMANDS=ON -S ${RMM_SOURCE_DIR} -B ${RMM_BUILD_DIR} cmake --build ${RMM_BUILD_DIR} -- cppcheck-misra cat ${RMM_BUILD_DIR}/tools/cppcheck/cppcheck_misra.xml 10. Perform a checkpatch analysis: Run checkpatch on commits in the current branch against BASE_COMMIT (default origin/master): .. code-block:: bash cmake -DRMM_CONFIG=fvp_defcfg -S ${RMM_SOURCE_DIR} -B ${RMM_BUILD_DIR} cmake --build ${RMM_BUILD_DIR} -- checkpatch Run checkpatch on entire codebase: .. code-block:: bash cmake -DRMM_CONFIG=fvp_defcfg -S ${RMM_SOURCE_DIR} -B ${RMM_BUILD_DIR} cmake --build ${RMM_BUILD_DIR} -- checkcodebase 11. Perform a checkspdx analysis: Run checkspdx on commits in the current branch against BASE_COMMIT (default origin/master): .. code-block:: bash cmake -DRMM_CONFIG=fvp_defcfg -S ${RMM_SOURCE_DIR} -B ${RMM_BUILD_DIR} cmake --build ${RMM_BUILD_DIR} -- checkspdx-patch Run checkspdx on entire codebase: .. code-block:: bash cmake -DRMM_CONFIG=fvp_defcfg -S ${RMM_SOURCE_DIR} -B ${RMM_BUILD_DIR} cmake --build ${RMM_BUILD_DIR} -- checkspdx-codebase 13. Check header file include order: Run checkincludes-patch on commits in the current branch against BASE_COMMIT (default origin/master): .. code-block:: bash cmake -DRMM_CONFIG=fvp_defcfg -S ${RMM_SOURCE_DIR} -B ${RMM_BUILD_DIR} cmake --build ${RMM_BUILD_DIR} -- checkincludes-patch Run checkincludes on entire codebase: .. code-block:: bash cmake -DRMM_CONFIG=fvp_defcfg -S ${RMM_SOURCE_DIR} -B ${RMM_BUILD_DIR} cmake --build ${RMM_BUILD_DIR} -- checkincludes-codebase 14. Perform a clang-tidy analysis: Run clang-tidy on commits in the current branch against BASE_COMMIT (default origin/master): .. code-block:: bash cmake -DRMM_CONFIG=fvp_defcfg -DRMM_TOOLCHAIN=llvm -DCMAKE_EXPORT_COMPILE_COMMANDS=ON -S ${RMM_SOURCE_DIR} -B ${RMM_BUILD_DIR} cmake --build ${RMM_BUILD_DIR} -- clang-tidy-patch Run clang-tidy on entire codebase: .. code-block:: bash cmake -DRMM_CONFIG=fvp_defcfg -DRMM_TOOLCHAIN=llvm -DCMAKE_EXPORT_COMPILE_COMMANDS=ON -S ${RMM_SOURCE_DIR} -B ${RMM_BUILD_DIR} cmake --build ${RMM_BUILD_DIR} -- clang-tidy-codebase Note that clang-tidy will work with all configurations. It will only check the source files that are used for the specified configuration. 15. Perform unit tests on development host: Build and run unit tests on host platform. It is recommended to enable the Debug build of RMM. .. code-block:: bash cmake -DRMM_CONFIG=host_defcfg -DHOST_VARIANT=host_test -DCMAKE_BUILD_TYPE=Debug -S ${RMM_SOURCE_DIR} -B ${RMM_BUILD_DIR} cmake --build ${RMM_BUILD_DIR} -- run-unittests Run unittests for a specific test group(s) (e.g. unittests whose group starts with 'xlat') .. code-block:: bash cmake -DRMM_CONFIG=host_defcfg -DHOST_VARIANT=host_test -DCMAKE_BUILD_TYPE=Debug -S ${RMM_SOURCE_DIR} -B ${RMM_BUILD_DIR} cmake --build ${RMM_BUILD_DIR} -- build -j ${RMM_BUILD_DIR}/Debug/rmm_core.elf -gxlat -v -r${NUMBER_OF_TEST_ITERATIONS} 16. Generate Coverage Report. It is possible to generate a coverage report for a last execution of the host platform (whichever the variant) by using the `run-coverage` build target. For example, to generate coverate report on the whole set of unittests: .. code-block:: bash cmake -DRMM_CONFIG=host_defcfg -DHOST_VARIANT=host_test -DRMM_COVERAGE=ON -DCMAKE_BUILD_TYPE=Debug -S ${RMM_SOURCE_DIR} -B ${RMM_BUILD_DIR} cmake --build ${RMM_BUILD_DIR} -- run-unittests cmake --build ${RMM_BUILD_DIR} -- run-coverage Run coverage analysis on a specific set of unittests (e.g. unittests whose group starts with 'xlat') .. code-block:: bash cmake -DRMM_CONFIG=host_defcfg -DHOST_VARIANT=host_test -DRMM_COVERAGE=ON -DCMAKE_BUILD_TYPE=Debug -S ${RMM_SOURCE_DIR} -B ${RMM_BUILD_DIR} cmake --build ${RMM_BUILD_DIR} -- build -j ${RMM_BUILD_DIR}/Debug/rmm_core.elf -gxlat cmake --build ${RMM_BUILD_DIR} -- run-coverage Run coverage analysis on the `host_build` variant of host platform: .. code-block:: bash cmake -DRMM_CONFIG=host_defcfg -DHOST_VARIANT=host_build -DRMM_COVERAGE=ON -DCMAKE_BUILD_TYPE=Debug -S ${RMM_SOURCE_DIR} -B ${RMM_BUILD_DIR} ${RMM_BUILD_DIR}/Debug/rmm_core.elf cmake --build ${RMM_BUILD_DIR} -- run-coverage The above commands will automatically generate the HTML coverage report in folder `build/Debug/coverage` within the build directory. The HTML generation can be disabled by setting `RMM_HTML_COV_REPORT=OFF`. 17. Run CBMC analysis: Run ``COVERAGE``, ``ANALYSIS`` and ``ASSERT`` targets for CBMC. The results are generated in ``${RMM_BUILD_DIR}/tools/cbmc/cbmc_coverage_results``. .. code-block:: bash cmake -DRMM_CONFIG=host_defcfg -DHOST_VARIANT=host_cbmc -S ${RMM_SOURCE_DIR} -B ${RMM_BUILD_DIR} cmake --build ${RMM_BUILD_DIR} -- cbmc-coverage cbmc-analysis cbmc-assert Refer to :ref:`CBMC` Application Note for details on installing and running CBMC. .. _build_options_table: ################### RMM Build Options ################### The |RMM| build system supports the following CMake build options. .. csv-table:: RMM CMake Options Table :header: "Option", "Valid values", "Default", "Description" RMM_CONFIG , , ,"Platform build configuration, eg: fvp_defcfg for the FVP" RMM_ARCH ,aarch64 | fake_host ,aarch64 ,"Target Architecture for RMM build" RMM_MAX_SIZE , ,0x0 ,"Maximum size for RMM image" MAX_CPUS , ,16 ,"Maximum number of CPUs supported by RMM" GRANULE_SHIFT , ,12 ,"Granule Shift used by RMM" RMM_CCA_TOKEN_BUFFER , ,1 ,"Number of pages to allocate in Aux granules for Realm CCA token" RMM_DOCS ,ON | OFF ,OFF ,"RMM Documentation build" CMAKE_BUILD_TYPE ,Debug | Release ,Release ,"CMake Build type" CMAKE_CONFIGURATION_TYPES ,Debug & Release ,Debug & Release ,"Multi-generator configuration types" CMAKE_DEFAULT_BUILD_TYPE ,Debug | Release ,Release ,"Default multi-generator configuration type" RMM_PLATFORM ,fvp | host , ,"Platform to build" RMM_TOOLCHAIN ,gnu | llvm , ,"Toolchain name" LOG_LEVEL ,0 - 50 ,40(Debug) 20(Release) ,"Log level to apply for RMM (0 - 50)." RMM_STATIC_ANALYSIS , , ,"Enable static analysis checkers" PL011_GENERIC_SBSA_UART ,ON | OFF ,OFF ,"Enable Generic (SBSA Compliant) PL011. This a subset of PL011 UART" PLAT_CMN_CTX_MAX_XLAT_TABLES , ,0 ,"Maximum number of translation tables used by the runtime context" PLAT_CMN_EXTRA_MMAP_REGIONS , ,0 ,"Extra platform mmap regions that need to be mapped in S1 xlat tables" PLAT_CMN_VIRT_ADDR_SPACE_WIDTH, ,38 ,"Stage 1 Virtual address space width in bits for this platform" RMM_NUM_PAGES_PER_STACK , ,5 ,"Number of pages to use per CPU stack" MBEDTLS_ECP_MAX_OPS ,248 - ,1000 ,"Number of max operations per ECC signing iteration" RMM_FPU_USE_AT_REL2 ,ON | OFF ,OFF(fake_host) ON(aarch64),"Enable FPU/SIMD usage in RMM." RMM_MAX_GRANULES , ,0 ,"Maximum number of memory granules available to the system" RMM_MAX_COH_GRANULES , ,1 ,"Maximum number of coherent device granules available to the system" RMM_MAX_NCOH_GRANULES , ,1 ,"Maximum number of non-coherent device granules available to the system" HOST_VARIANT ,host_build | host_test | host_cbmc ,host_build ,"Variant to build for the host platform. Only available when RMM_PLATFORM=host" HOST_DRAM_SIZE , ,0x20000000 ,"Host memory size that will be used as physical DRAM" HOST_NCOH_DEV_SIZE , ,0xA000 ,"Host memory size that will be used as non-coherent device granules" RMM_COVERAGE ,ON | OFF ,OFF ,"Enable coverage analysis" RMM_HTML_COV_REPORT ,ON | OFF ,ON ,"Enable HTML output report for coverage analysis" RMM_CBMC_VIEWER_OUTPUT ,ON | OFF ,OFF ,"Generate report of CBMC results using the tool cbmc-viewer" RMM_CBMC_SINGLE_TESTBENCH , ,OFF ,"Run CBMC on a single testbench instead on all of them" RMM_MEM_SCRUB_METHOD ,0 - 2 ,0 ,"Memory Scrub method selection when granule are returned to NS Host." RMM_V1_1 ,ON | OFF ,OFF ,"Enable v1.1 features (experimental)" ATTEST_PLAT_TOKEN_SIZE , ,0x1000 ,"Maximum size in bytes expected for the Attestation platform token" PLAT_ARM_MAX_MEM_BANKS , ,2 ,"Maximum possible number of DRAM and COH/NCOH device memory banks allowed in Arm platform layer" ATTEST_EL3_TOKEN_SIGN ,ON|OFF ,OFF ,"Use EL3 service to sign realm attestation token." STACK_PROTECTOR ,ON | OFF ,OFF ,"Enable the stack protector compiler option." UBSAN ,ON | OFF ,OFF ,"Enable Undefined Behavior Sanitizer." .. _llvm_build: ################ RMM LLVM Build ################ RMM can be built using LLVM Toolchain (Clang). To build using LLVM toolchain, set RMM_TOOLCHAIN=llvm during configuration stage. .. _fake_host_build: ##################### RMM Fake Host Build ##################### RMM also provides a ``fake_host`` target architecture which allows the code to be built natively on the host using the host toolchain. To build for ``fake_host`` architecture, set RMM_CONFIG=host_defcfg during the configuration stage.
