19. Building with Shrinkwrap
This document explains how to build and run RMM in FVP, including all necessary firmware images, by using Shrinkwrap.
19.1. Introduction
Shrinkwrap is a tool that helps to simplify the process of building and running firmware on Arm FVP by providing an intuitive command line interface frontend and (by default) a container-based backend.
Shrinkwrap works by using configs, which are defined in YAML and can be easily extended using a built-in layering system.
For instructions on how to setup Shrinkwrap on your local machine as well as for further information, you can refer to the Quick Start Guide. In particular, for development with RME enabled Linux in Normal World, please refer to the 3 world configuration. In case that the Secure World also needs to be included, please refer to the 4 world configuration
19.2. Setup local RMM with Shrinkwrap
This section assumes that you have your local RMM repository cloned and that it is used for your development. In order to help using Shrinkwrap with your development workflow, the project provides some configs and overlays.
Also, from now on, it is assumed that your current directory (pointed by ${PWD}) is the root of your RMM development repository.
In order to use the configs defined in RMM, it is essential to configure the ${SHRINKWRAP_CONFIG} environment variable to point to ${PWD}/tools/shrinkwrap/configs directory so the tool can locate the config yaml files.
export SHRINKWRAP_CONFIG=${PWD}/tools/shrinkwrap/configs
It is also recommended to override the default ${SHRINKWRAP_BUILD} and ${SHRINKWRAP_PACKAGE} environment variables to a known workspace directory, as shown below:
export WORKSPACE=${HOME}/workspace
export SHRINKWRAP_BUILD=${WORKSPACE}
export SHRINKWRAP_PACKAGE=${SHRINKWRAP_BUILD}/package
When building, Shrinkwrap will store the sources inside ${SHRINKWRAP_BUILD}/source/<CONFIG_NAME> and the build artifacts and packages will be stored inside ${SHRINKWRAP_BUILD}/build/<CONFIG_NAME> and ${SHRINKWRAP_PACKAGE}/<CONFIG_NAME> directories respectively.
By default, if ${SHRINKWRAP_BUILD} and ${SHRINKWRAP_PACKAGE} are not specified, Shrinkwrap will use the ${HOME}/.shrinkwrap as default value for ${SHRINKWRAP_BUILD}. It is only necessary to overwrite the environment variables in the case it is needed to build in a different location.
19.3. 3-World testing
RMM provides a number of overlays that can be used in conjunction with some of the configs provided by Shrinkwrap. One of the overlays, specifically cca.yaml, can be used along with the cca-3world.yaml to build a 3 World demonstrator using the master branch of TF-A and the local RMM repository.
As an example, the following command line would build the 3-World demonstrator. It assumes that Shrinkwrap is called from within the <RMM_ROOT> directory:
shrinkwrap build cca-3world.yaml --overlay=cca.yaml --btvar=GUEST_ROOTFS='${artifact:BUILDROOT}' --btvar=RMM_SRC=${PWD} --no-sync=rmm
You can find further instructions on how to build and package the filesystem and required binaries in the 3 world configuration documentation.
To run the demonstrator, use the following command:
shrinkwrap run cca-3world.yaml --overlay=cca.yaml --rtvar=ROOTFS=${SHRINKWRAP_PACKAGE}/cca-3world/rootfs.ext2
Finally, once the host has booted, log in as “root” (no password). Now, launch a realm using kvmtool from the /cca directory (that was created above):
cd /cca
./lkvm run --realm -c 2 -m 256 --disk guest-disk.img --kernel Image \
    -p "earlycon=uart,mmio,0x101000000 root=/dev/vda2 swiotlb=16384"
The swiotlb=16384 guest kernel parameter requests 32 MiB of DMA bounce buffers to avoid swiotlb buffer is full errors during boot.
You should see the realm guest booting to shell. You can now test the basic functionality of RMM by running some commands in the realm shell, for example:
ls /dev/vda2
cat /proc/cpuinfo
To power off the realm guest, run:
poweroff -f
19.4. 3-World testing with CCA DA
Follow the instructions in Setup local RMM with Shrinkwrap to setup the local RMM with shrinkwrap.
RMM provides cca_da.yaml overlay that can be used along with the cca-3world.yaml to build a 3 World demonstrator.
The FVP SMMU runs without Broadcast TLB Maintenance (BTM) by default. Add the model-enable-btm.yaml overlay to the build and run commands when testing with BTM enabled.
As an example, the following command line would build the 3-World demonstrator. It assumes that Shrinkwrap is called from within the <RMM_ROOT> directory that was created in the last step:
shrinkwrap build cca-3world.yaml --overlay=cca_da.yaml --btvar GUEST_ROOTFS='${artifact:BUILDROOT}' --btvar RMM_SRC=${PWD} --no-sync=rmm
Follow the steps mentioned in 3 world configuration documentation to copy guest-disk.img, Image, KVMTOOL_EFI.fd and lkvm to the host filesystem.
Now you can boot the host, using the rootfs we just modified.
shrinkwrap run cca-3world.yaml --overlay=cca_da.yaml --rtvar ROOTFS=${SHRINKWRAP_PACKAGE}/cca-3world/rootfs.ext2
Finally, once the host has booted, log in as “root” (no password). Below are the device assignment workflow based on the DA workflow cover letter from the Linux kernel prototype branch.
Connect the device with TSM, this establishes secure session to the device and enables IDE in the link.
echo 0000:02:00.0 > /sys/bus/pci/devices/0000:02:00.0/driver/unbind
echo vfio-pci > /sys/bus/pci/devices/0000:02:00.0/driver_override
echo 0000:02:00.0 > /sys/bus/pci/drivers_probe
echo tsm0 > /sys/bus/pci/devices/0000:02:00.0/tsm/connect
cd /cca
    -p "earlycon=uart,mmio,0x101000000 root=/dev/vda2" \
    --vfio-pci 0000:02:00.0
Be patient while this boots to the shell.
Now in the Realm we follow the below steps on the assigned device to move the device to TDISP LOCKED and RUN state. At this step the Realm verifies the device attestation evidence that it got from the Host are valid by computing the digest and comparing it with the value it got from the RMM.
echo 0000:00:00.0 > /sys/bus/pci/devices/0000:00:00.0/driver/unbind
echo tsm0 > /sys/bus/pci/devices/0000:00:00.0/tsm/lock
echo 1 > /sys/bus/pci/devices/0000:00:00.0/tsm/accept
Load the driver
echo 0000:00:00.0 > /sys/bus/pci/drivers_probe
If everything went well, you should see the driver loading and the following lines in the console:
ata1: SATA max UDMA/133 abar m8192@0x50006000 port 0x50006100 irq 22 lpm-pol 1
ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
ata1.00: ATA-10: ahci-disk.img, 0.1.0, max MWDMA2
ata1.00: 131072 sectors, multi 0: LBA48 NCQ (depth 1)
ata1.00: configured for PIO4
scsi 0:0:0:0: Direct-Access     ATA      ahci-disk.img    0    PQ: 0 ANSI: 5
sd 0:0:0:0: [sda] 131072 512-byte logical blocks: (67.1 MB/64.0 MiB)
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
sd 0:0:0:0: [sda] Preferred minimum I/O size 512 bytes
sd 0:0:0:0: [sda] Attached SCSI disk
Also the device should be visible as a device in /dev , in this case /dev/sda will be visible. You can now partition, format and mount the device as you would do with any other block device.
19.5. Testing RMM with TFTF
RMM provides a config that brings together a software stack to test RMM and Arm RME extension utilizing TF-A-Tests. The main Test payload in TF-A-Tests is the TFTF binary. In this config, TF-A is in Root World, RMM is in Realm EL2 and TFTF is in Normal World.
In order to build the config, you need to run the following command:
shrinkwrap build --btvar=RMM_SRC=${PWD} rmm-tftf.yaml --no-sync=rmm
and you can run it through
shrinkwrap run rmm-tftf.yaml
For further documentation about this configuration, you can check the docs through
shrinkwrap inspect rmm-tftf.yaml
The build and run commands can also be found in the documentation of the config yaml file. When invoking the build command, Shrinkwrap will store the external repositories inside the ${SHRINKWRAP_BUILD}/sources/<CONFIG_NAME> directory.
19.6. Overlays
Overlays can be used to extend the functionality of a config by overwriting both build and runtime settings. They can be used on any configuration and they can be combined in any way needed.
In order to use an overlay, they need to be specified on the command line, through the --overlay keyword, as follows:
shrinkwrap build rmm-tftf.yaml --btvar=RMM_SRC=${PWD} --overlay=<OVERLAY_FILE_NAME> --no-sync=rmm
shrinkwrap run rmm-tftf.yaml --overlay=<OVERLAY_FILE_NAME>
The path to the overlay can be relative to where Shrinkwrap is called from and you can use as many --overlay statements as needed.
Overlays are stored in the <RMM_ROOT_DIR>/tools/shrinkwrap/configs/ directory, alongside with the configuration files.
The available Overlays are sumarized in the next table
Overlay
cca.yaml
Overlay to build and run RMM in a 3-World CCA demonstrator configuration using the local RMM repository and TF-A master branch.
cca_da.yaml
Overlay to build and run RMM in a 3-World CCA demonstrator configuration with Device Assignment (DA) support for RMM v1.x branches.
lfa-support.yaml
Overlay to build TF-A with LFA support enabled and load LFA RMM at expected address.
model-enable-lpa2.yaml
Overlay used to enable FEAT_LPA2 on the FVP model at run time. In addition this overlay also sets the PA_SIZE on the model to 52
Overlay used to enable SMMUv3 Broadcast TLB Maintenance on the FVP model at run time.
model-enable-mec.yaml
Overlay used to enable FEAT_MEC on the FVP model at run time.
model-enable-mops.yaml
Overlay used to enable FEAT_MOPS on the FVP model at run time.
model-wait-debugger.yaml
Overlay to configure the FVP model to listen for Iris connections on port 7100 and make it wait until a debugger is connected before starting execution
model-enable-s2pie-s2poe.yaml
Overlay to enable FEAT_S2PIE and FEAT_S2POE on the FVP model at run time.
model-enable-feat_d128.yaml
Overlay used to enable FEAT_D128 on the FVP model at runtime.
rmm-tftf-2mb-tracking.yaml
Overlay to configure TFTF Realm tests to use 2 MB RMM tracking regions.
rmm-debug.yaml
Overlay to build RMM (as well as TF-A) in debug mode
clean.yaml
Overlay used to avoid an exception with Shrinkwrap clean in which a path with a valid format needs to be specified for RMM
19.6.1. Example of use
Below is an example on how to use one of the available overlays with the existing configuration. The example specifies --runtime=null to use the native toolchain (without the Docker container) to build the artifacts and --no-sync-all to prevent Shrinkwrap from updating/cleaning any of the repositories:
shrinkwrap --runtime=null build rmm-tftf.yaml --overlay=model-enable-lpa2.yaml --btvar=RMM_SRC=${PWD} --no-sync-all
Then you run your tests with
shrinkwrap --runtime=null run rmm-tftf.yaml
To test RMM Live Firmware Activation (LFA) support, you can use the lfa-support.yaml overlay along with other overlays as needed:
shrinkwrap build --btvar=RMM_SRC=${PWD} --overlay=rmm-debug.yaml --overlay=lfa-support.yaml rmm-tftf.yaml --no-sync-all
To run the tests with MEC enabled :
shrinkwrap run --overlay model-enable-mec.yaml --overlay=lfa-support.yaml rmm-tftf.yaml
Note that runtime=null is specified for the run, as it must match the same setting as used on the build stage. Also, with this setting, the appropriate FVP (FVP_Base_RevC-2xAEMvA) needs to be present in the system ${PATH}.
