.. SPDX-License-Identifier: BSD-3-Clause .. SPDX-FileCopyrightText: Copyright TF-RMM Contributors. .. _using_shrinkwrap_with_rmm: Building with Shrinkwrap ************************ This document explains how to build and run |RMM| in |FVP|, including all necessary firmware images, by using `Shrinkwrap`_. Introduction ____________ `Shrinkwrap`_ is a tool that helps to simplify the process of building and running firmware on Arm |FVP| by providing an intuitive command line interface frontend and (by default) a container-based backend. Shrinkwrap works by using *configs*, which are defined in YAML and can be easily extended using a built-in layering system. For instructions on how to setup Shrinkwrap on your local machine as well as for further information, you can refer to the `Quick Start Guide`_. In particular, for development with RME enabled Linux in Normal World, please refer to the `3 world configuration`_. In case that the Secure World also needs to be included, please refer to the `4 world configuration`_ .. _Setup_local_RMM_with_Shrinkwrap: Setup local RMM with Shrinkwrap _______________________________ This section assumes that you have your local |RMM| repository cloned and that it is used for your development. In order to help using Shrinkwrap with your development workflow, the project provides some configs and overlays. Also, from now on, it is assumed that your current directory (pointed by ``${PWD}``) is the root of your |RMM| development repository. In order to use the configs defined in |RMM|, it is essential to configure the ``${SHRINKWRAP_CONFIG}`` environment variable to point to ``${PWD}/tools/shrinkwrap/configs`` directory so the tool can locate the config yaml files. .. code-block:: shell export SHRINKWRAP_CONFIG=${PWD}/tools/shrinkwrap/configs It is also recommended to override the default ``${SHRINKWRAP_BUILD}`` and ``${SHRINKWRAP_PACKAGE}`` environment variables to a known workspace directory, as shown below: .. code-block:: shell export WORKSPACE=${HOME}/workspace export SHRINKWRAP_BUILD=${WORKSPACE} export SHRINKWRAP_PACKAGE=${SHRINKWRAP_BUILD}/package When building, Shrinkwrap will store the sources inside ``${SHRINKWRAP_BUILD}/source/`` and the build artifacts and packages will be stored inside ``${SHRINKWRAP_BUILD}/build/`` and ``${SHRINKWRAP_PACKAGE}/`` directories respectively. .. note:: By default, if ${SHRINKWRAP_BUILD} and ${SHRINKWRAP_PACKAGE} are not specified, Shrinkwrap will use the ``${HOME}/.shrinkwrap`` as default value for ${SHRINKWRAP_BUILD}. It is only necessary to overwrite the environment variables in the case it is needed to build in a different location. .. _3_world_testing: 3-World testing _______________ |RMM| provides a number of overlays that can be used in conjunction with some of the configs provided by Shrinkwrap. One of the overlays, specifically ``rmm.yaml``, can be used along with the ``cca-3world.yaml`` to build a 3 World demonstrator using the ``master`` branch of |TF-A| and the local |RMM| repository. As an example, the following command line would build the 3-World demonstrator. It assumes that Shrinkwrap is called from within the ```` directory: .. code-block:: shell shrinkwrap build cca-3world.yaml --overlay=buildroot.yaml --overlay=rmm.yaml --btvar=GUEST_ROOTFS='${artifact:BUILDROOT}' --btvar=RMM_SRC=${PWD} --no-sync=rmm You can find further instructions on how to build and package the filesystem and required binaries in the `3 world configuration`_ documentation. To run the demonstrator, use the following command: .. code-block:: shell shrinkwrap run cca-3world.yaml --rtvar=ROOTFS=${SHRINKWRAP_PACKAGE}/cca-3world/rootfs.ext2 3-World testing with CCA DA ___________________________ Clone TF-RMM repository at branch ``topics/da_alp12`` .. code-block:: shell git clone https://git.trustedfirmware.org/TF-RMM/tf-rmm.git Follow the instructions in :ref:`Setup_local_RMM_with_Shrinkwrap` to setup the local RMM with shrinkwrap. RMM provides ``cca_da.yaml`` overlay that can be used along with the ``cca-3world.yaml`` to build a 3 World demonstrator using the ``master`` branch of |TF-A|, ``cca/tdisp-upstream-post-v1.3`` branch of Linux kernel, kvmtool, and the local clone of RMM repository from ``main`` branch. As an example, the following command line would build the 3-World demonstrator. It assumes that Shrinkwrap is called from within the ```` directory that was created in the last step: .. code-block:: shell shrinkwrap build cca-3world.yaml --overlay=cca_da.yaml --btvar GUEST_ROOTFS='${artifact:BUILDROOT}' --btvar RMM_SRC=${PWD} --no-sync=rmm Follow the steps mentioned in `3 world configuration`_ documentation to copy guest-disk.img, KVMTOOL_EFI.fd and lkvm to the host filesystem. Shrinkwrap expects the FVP binary (FVP_Base_RevC-2xAEMvA) to be in your PATH. The ``runtime=null`` option is used to run the FVP directly from the PATH, without using the Docker container. Make sure that the FVP version is **10034** or higher, as older FVP versions have issues that prevent this demo from working. Now you can boot the host, using the rootfs we just modified. .. code-block:: shell shrinkwrap --runtime=null run cca-3world.yaml --overlay=cca_da.yaml --rtvar ROOTFS=${SHRINKWRAP_PACKAGE}/cca-3world/rootfs.ext2 Finally, once the host has booted, log in as “root” (no password). Below are the device assignment workflow based on the `DA workflow`_ cover letter from the Linux kernel prototype branch. Connect the device with TSM, this establishes secure session to the device and enables IDE in the link. .. code-block:: shell echo 0000:02:00.0 > /sys/bus/pci/devices/0000:02:00.0/driver/unbind echo vfio-pci > /sys/bus/pci/devices/0000:02:00.0/driver_override echo 0000:02:00.0 > /sys/bus/pci/drivers_probe echo tsm0 > /sys/bus/pci/devices/0000:02:00.0/tsm/connect Now, launch a realm using kvmtool from the /cca directory (that was created above): .. code-block:: shell cd /cca ./lkvm run --realm -c 2 -m 256 --disk guest-disk.img --kernel Image -p "earlycon=uart,mmio,0x101000000 root=/dev/vda2" --iommufd-vdevice --vfio-pci 0000:02:00.0 Be patient while this boots to the shell. Now in the Realm we follow the below steps on the assigned device to move the device to TDISP LOCKED and RUN state. At this step the Realm verifies the device attestation evidence that it got from the Host are valid by computing the digest and comparing it with the value it got from the RMM. .. code-block:: shell echo 0000:00:00.0 > /sys/bus/pci/devices/0000:00:00.0/driver/unbind echo tsm0 > /sys/bus/pci/devices/0000:00:00.0/tsm/lock echo 1 > /sys/bus/pci/devices/0000:00:00.0/tsm/accept Load the driver .. code-block:: shell echo 0000:00:00.0 > /sys/bus/pci/drivers_probe If everything went well, you should see the driver loading and the following lines in the console: .. code-block:: console ata1: SATA max UDMA/133 abar m8192@0x50006000 port 0x50006100 irq 22 lpm-pol 1 ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300) ata1.00: ATA-10: ahci-disk.img, 0.1.0, max MWDMA2 ata1.00: 131072 sectors, multi 0: LBA48 NCQ (depth 1) ata1.00: configured for PIO4 scsi 0:0:0:0: Direct-Access ATA ahci-disk.img 0 PQ: 0 ANSI: 5 sd 0:0:0:0: [sda] 131072 512-byte logical blocks: (67.1 MB/64.0 MiB) sd 0:0:0:0: [sda] Write Protect is off sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA sd 0:0:0:0: [sda] Preferred minimum I/O size 512 bytes sd 0:0:0:0: [sda] Attached SCSI disk Also the device should be visible as a device in `/dev` , in this case /dev/sda will be visible. You can now partition, format and mount the device as you would do with any other block device. Testing RMM with TFTF _____________________ |RMM| provides a config that brings together a software stack to test |RMM| and Arm RME extension utilizing `TF-A-Tests`_. The main Test payload in TF-A-Tests is the |TFTF| binary. In this config, |TF-A| is in Root World, |RMM| is in Realm EL2 and |TFTF| is in Normal World. In order to build the config, you need to run the following command: .. code-block:: shell shrinkwrap build --btvar=RMM_SRC=${PWD} rmm-tftf.yaml --no-sync=rmm and you can run it through .. code-block:: shell shrinkwrap run rmm-tftf.yaml For further documentation about this configuration, you can check the docs through .. code-block:: shell shrinkwrap inspect rmm-tftf.yaml The build and run commands can also be found in the documentation of the config yaml file. When invoking the ``build`` command, Shrinkwrap will store the external repositories inside the ``${SHRINKWRAP_BUILD}/sources/`` directory. Overlays ________ Overlays can be used to extend the functionality of a config by overwriting both build and runtime settings. They can be used on any configuration and they can be combined in any way needed. In order to use an overlay, they need to be specified on the command line, through the ``--overlay`` keyword, as follows: .. code-block:: shell shrinkwrap build rmm-tftf.yaml --btvar=RMM_SRC=${PWD} --overlay= --no-sync=rmm The path to the overlay can be relative to where Shrinkwrap is called from and you can use as many ``--overlay`` statements as needed. Overlays are stored in the ``/tools/shrinkwrap/configs/`` directory, alongside with the configuration files. The available Overlays are sumarized in the next table .. csv-table:: :header: "Overlay", "Description" :widths: 2 8 model-enable-lpa2.yaml,Overlay used to enable ``FEAT_LPA2`` on the |FVP| model at run time. In addition this overlay also sets the ``PA_SIZE`` on the model to 52 model-enable-mec.yaml,Overlay used to enable ``FEAT_MEC`` on the |FVP| model at run time. model-wait-debugger.yaml,Overlay to configure the |FVP| model to listen for Iris connections on port 7100 and make it wait until a debugger is connected before starting execution model-enable-s2pie-s2poe.yaml,Overlay to enable ``FEAT_S2PIE`` and ``FEAT_S2POE`` on the |FVP| model at run time. model-enable-feat_d128.yaml,Overlay used to enable ``FEAT_D128`` on the |FVP| model at runtime. rmm-debug.yaml,Overlay to build |RMM| (as well as |TF-A|) in debug mode rmm-v1_1.yaml,Overlay to build |RMM| with v1.1 features clean.yaml,Overlay used to avoid an exception with ``Shrinkwrap clean`` in which a path with a valid format needs to be specified for |RMM| Example of use ~~~~~~~~~~~~~~ Below is an example on how to use one of the available overlays with the existing configuration. The example specifies ``--runtime=null`` to use the native toolchain (without the Docker container) to build the artifacts and ``--no-sync-all`` to prevent Shrinkwrap from updating/cleaning any of the repositories: .. code-block:: shell shrinkwrap --runtime=null build rmm-tftf.yaml --overlay=model-enable-lpa2.yaml --btvar=RMM_SRC=${PWD} --no-sync-all Similarly you can use overlay rmm-v1_1.yaml to enable RMM v1.1 features along with rmm-debug.yaml to enable debug build. .. code-block:: shell shrinkwrap --runtime=null build rmm-tftf.yaml --overlay=rmm-v1_1.yaml --overlay=rmm-debug.yaml --btvar=RMM_SRC=${PWD} --no-sync-all Then you run your tests with .. code-block:: shell shrinkwrap --runtime=null run rmm-tftf.yaml .. note:: Note that ``runtime=null`` is specified for the run, as it must match the same setting as used on the build stage. Also, with this setting, the appropriate FVP (FVP_Base_RevC-2xAEMvA) needs to be present in the system ${PATH}. FVP version must be >= ``11.29.27`` when rmm-v1_1.yaml overlay is used. ----- .. _Shrinkwrap: https://shrinkwrap.docs.arm.com .. _Quick Start Guide: https://shrinkwrap.docs.arm.com/en/latest/userguide/quickstart.html#quick-start-guide .. _3 world configuration: https://shrinkwrap.docs.arm.com/en/latest/userguide/configstore/cca-3world.html .. _4 world configuration: https://shrinkwrap.docs.arm.com/en/latest/userguide/configstore/cca-4world.html .. _TF-A-Tests: https://trustedfirmware-a-tests.readthedocs.io/en/latest/index.html .. _btvar: https://shrinkwrap.docs.arm.com/en/latest/userguide/configmodel.html#defined-macros .. _rtvar: https://shrinkwrap.docs.arm.com/en/latest/userguide/configmodel.html#defined-macros .. _DA workflow: https://gitlab.geo.arm.com/software/linux-arm/linux-kernel-aneesh/-/commit/10cee3cb39ee53738fbb722181c9cd2b5f42189d
