1.3. Threat Analysis components
In this section we identify all the possible actors involved in the Threat Model.
For each threat, we will identify the asset that is under threat, the threat agent and the threat type. Each threat will be given a risk rating that represents the impact and likelihood of that threat.
Any threat which needs to be mitigated by the RME hardware as well as by EL3 Root code is out of the scope of this Threat Model.
1.3.1. Assets
We have identified the following assets for RMM:
Asset |
Description |
Sensitive Data |
These include sensitive RMM and Realm data that
an attacker must not be able to tamper with.
Also, RMM should protect the confidentiality of
of such data.
Code Execution |
This represents the requirement that Realms
should only run code in R-EL1/EL0 that is
allowed by the RMM ABI. The Realm code execution
cannot be hijacked by an attacker.
This also represents the requirement that RMM
should protect itself from privilege escalation
and code injection by an attacker into R-EL2.
The RMM execution cannot be hijacked by an
attacker through the use of the RMM ABI.
Availability |
Availability of Realm world is out of scope for
this Threat Model. However, RMM should be
designed in such a way that neither Realm nor
RMM should significantly affect the availability
of NS Host and Secure World.
1.3.2. Threat Agents
To understand the attack surface, it is important to identify potential attackers, i.e. attack entry points. The following threat agents are in scope of this threat model.
Threat Agent |
Description |
RealmCode |
Malicious or faulty code running in the Realm
world, including R-EL0 and R-EL1 levels.
HostSoftware |
Malicious or faulty code running in the Secure or
Non-Secure world, EL0 and EL1 levels.
AppDebug |
Physical adversary using debug build of RMM or
access to debug sources of the system.
There is also a number of Threat Agents which are not covered by this Threat Model. These are listed in the table below.
Threat Agent |
Description |
RootCode |
Malicious or faulty code running at Root Level
(e.g. EL3 Firmware). Since RootCode is part of TCB
of the system, any fault in Root code is usually a
critical vulnerability and not easily mitigated by
RMM. This Threat is considered out-of-scope of
analysis.
PhysicalAccess |
Physical adversary having access to external device
communication bus and to external flash
communication bus using common hardware.
An advanced physical atacker that has the capability
to tamper with hardware (e.g. “rewiring” a chip
using a focused ion beam -FIB- workstation or
decapsulate the chip using chemicals).
1.3.3. Threat Types
In this threat model we categorize threats using the STRIDE threat
analysis technique. In this technique a threat is categorized as one
or more of these types: Spoofing, Tampering, Repudiation,
Information disclosure, Denial of service or
Elevation of privilege.
1.3.4. Threat Risk Ratings
For each threat identified, a risk rating that ranges from informational to critical is given based on the likelihood of the threat occurring if a mitigation is not in place, and the impact of the threat (i.e. how severe the consequences could be). Table 4 explains each rating in terms of score, impact and likelihood.
Rating (Score) |
Likelihood |
Critical (5) |
Extreme impact to
entire organization
if exploited.
Threat is almost
certain to be exploited.
Knowledge of the threat
and how to exploit it
are in the public
domain.
High (4) |
Major impact to entire
organization or single
line of business if
exploited
Threat is relatively
easy to detect and
exploit by an attacker
with little skill.
Medium (3) |
Noticeable impact to
line of business if
exploited.
A knowledgeable insider
or expert attacker could
exploit the threat
without much difficulty.
Low (2) |
Minor damage if
exploited or could
be used in conjunction
with other
vulnerabilities to
perform a more serious
attack
Exploiting the threat
would require
considerable expertise
and resources
Informational (1) |
Poor programming
practice or poor
design decision that
may not represent an
immediate risk on its
own, but may have
security implications
if multiplied and/or
combined with other
threats.
Threat is not likely
to be exploited on its
own, but may be used to
gain information for
launching another
attack
Aggregate risk scores are assigned to identified threats. Specifically, the impact score multiplied by the likelihood score. For example, a threat with high likelihood and low impact would have an aggregate risk score of eight (8); that is, four (4) for high likelihood multiplied by two (2) for low impact. The aggregate risk score determines the finding’s overall risk level, as shown in the following table.
Overall Risk Level |
Aggregate Risk Score (Impact multiplied by Likelihood) |
Critical |
20-25 |
High |
12-19 |
Medium |
6-11 |
Low |
2-5 |
Informational |
1 |
The likelihood and impact of a threat depends on the
target environment in which RMM is running. For example, attacks
that require physical access are unlikely in server environments while
they are more common in Internet of Things (IoT) environments.
In this threat model we only consider Server target environments.
