.. SPDX-License-Identifier: BSD-3-Clause .. SPDX-FileCopyrightText: Copyright TF-RMM Contributors. .. _getting_started: ############# Prerequisite ############# This document describes the software requirements for building |RMM| for AArch64 target platforms. It may possible to build |RMM| with combinations of software packages that are different from those listed below, however only the software described in this document can be officially supported. ########### Build Host ########### The |RMM| officially supports a limited set of build environments and setups. In this context, official support means that the environments listed below are actively used by team members and active developers, hence users should be able to recreate the same configurations by following the instructions described below. In case of problems, the |RMM| team provides support only for these environments, but building in other environments can still be possible. We recommend at least Ubuntu 20.04 LTS (x64) for build environment. The arm64/AArch64 Ubuntu and other Linux distributions should also work fine, provided that the necessary tools and libraries can be installed. .. _tool_dependencies: ########################## Tool & Dependency overview ########################## The following tools are required to obtain and build |RMM|: .. csv-table:: Tool dependencies :header: "Name", "Version", "Component" "C compiler", see :ref:`getting_started_toolchain` ,"Firmware" "CMake", ">=3.20.0", "Firmware, Documentation" "GNU Make", ">4.0", "Firmware, Documentation" "Python",3.x,"Firmware, Documentation" "Perl",>=5.26,"Firmware, Documentation" "ninja-build",,"Firmware (using Ninja Generator)" "Sphinx",">=2.4,<3.0.0","Documentation" "sphinxcontrib-plantuml",,"Documentation" "sphinx-rtd-theme",,"Documentation" "Git",, "Firmware, Documentation" "Graphviz dot",">v2.38.0","Documentation" "docutils",">v2.38.0","Documentation" "gcovr",">=v4.2","Tools(Coverage analysis)" "CBMC",">=5.84.0","Tools(CBMC analysis)" "Cppcheck",">=2.18.0","Tools(Cppcheck)" "pyelftools","==0.32","Firmware (EL0 app)" "Clang-tidy",">=18.1.8","Tools(clang-tidy)" .. _getting_started_toolchain: ############### Setup Toolchain ############### To compile |RMM| code for an AArch64 target, at least one of the supported AArch64 toolchains have to be available in the build environment. Currently, the following compilers are supported: - GCC (aarch64-none-elf-) >= 11.2-2022.02 (from the `Arm GNU Toolchain downloads`_) - Clang+LLVM >= 14.0.0 (from the `LLVM Releases website`_) The respective compiler binary must be found in the shell's search path. Be sure to add the bin/ directory if you have downloaded a binary version. The toolchain to use can be set using ``RMM_TOOLCHAIN`` parameter and can be set to either `llvm` or `gnu`. The default toolchain is `gnu`. For non-native AArch64 target build, the ``CROSS_COMPILE`` environment variable must contain the right target triplet corresponding to the AArch64 GCC compiler. Below is an example when RMM is to be built for AArch64 target on a non-native host machine and using GCC as the toolchain. .. code-block:: bash export CROSS_COMPILE=aarch64-none-elf- export PATH=/bin:$PATH Please note that AArch64 GCC must be included in the shell's search path even when using Clang as the compiler as LLVM does not include some C standard headers like `stdlib.h` and needs to be picked up from the `include` folder of the AArch64 GCC. Below is an example when RMM is to be built for AArch64 target on a non-native host machine and using LLVM as the toolchain. .. code-block:: bash export CROSS_COMPILE=aarch64-none-elf- export PATH=/bin:/bin:$PATH The ``CROSS_COMPILE`` variable is ignored for ``fake_host`` build and the native host toolchain is used for the build. ####################################### Package Installation (Ubuntu-20.04 x64) ####################################### If you are using the recommended Ubuntu distribution then we can install the required packages with the following commands: 1. Install dependencies: .. code:: shell sudo apt-get install -y git build-essential python3 python3-pip make ninja-build sudo snap install cmake 2. Verify cmake version: .. code-block:: bash cmake --version .. note:: Please download cmake 3.20 or later version from https://cmake.org/download/. 3. Add CMake path into environment: .. code-block:: bash export PATH=/bin:$PATH ########################### Install python dependencies ########################### RMM's ``requirements.txt`` file declares additional Python dependencies. Install them with ``pip3``: .. code-block:: bash pip3 install --upgrade pip cd pip3 install -r requirements.txt ############################################# Install python dependencies for Documentation ############################################# .. note:: The installation of Python dependencies for documentation is an optional step. This is required only if building documentation. RMM's ``docs/requirements.txt`` file declares additional Python dependencies. Install them with ``pip3``: .. code-block:: bash pip3 install --upgrade pip cd pip3 install -r docs/requirements.txt ############################################ Install coverage tools analysis dependencies ############################################ .. note:: This is an optional step only needed if you intend to run coverage analysis on the source code. On Ubuntu, ``gcovr`` tool can be installed in two different ways: Using the package manager: .. code-block:: bash sudo apt-get install gcovr The second (and recommended) way is install it with ``pip3``: .. code-block:: bash pip3 install --upgrade pip pip3 install gcovr .. _getting_started_get_source: ######################### Getting the RMM Source ######################### Source code for |RMM| is maintained in a Git repository hosted on TrustedFirmware.org. To clone this repository from the server, run the following in your shell: .. code-block:: bash git clone https://git.trustedfirmware.org/TF-RMM/tf-rmm.git Note that the RMM submodule dependencies will be updated during the configuration phase of build. Additional steps for Contributors ********************************* If you are planning on contributing back to RMM, your commits need to include a ``Change-Id`` footer as explained in :ref:`mandated-trailers`. This footer is generated by a Git hook that needs to be installed inside your cloned RMM source folder. The `TF-RMM Gerrit page`_ under trustedfirmware.org contains a *Clone with commit-msg hook* subsection under its **Download** header where you can copy the command to clone the repo with the required git hooks. Please use the **SSH** option to clone the repository on your local machine. If needed, you can also manually install the hooks separately on an existing repo: .. code:: shell curl -Lo $(git rev-parse --git-dir)/hooks/commit-msg https://review.trustedfirmware.org/tools/hooks/commit-msg chmod +x $(git rev-parse --git-dir)/hooks/commit-msg You can read more about Git hooks in the *githooks* page of the `Git hooks documentation`_. General contribution guidelines for contributors can be found in :ref:`Contributor's Guide`. ################################# Install Cppcheck and dependencies ################################# .. note:: The installation of Cppcheck is an optional step. This is required only if using the Cppcheck static analysis. The recommended version of Cppcheck is indicated in :ref:`tool_dependencies`. See :ref:`Cppcheck Application Note` for installation steps and details on how to use it within RMM build system. ############ Install CBMC ############ .. note:: The installation of CBMC is an optional step. This is required only if running source code analysis with CBMC. Follow the public documentation to install CBMC either from the official website https://www.cprover.org/cbmc/ or from the official github https://github.com/diffblue/cbmc Refer to :ref:`CBMC` Application Notes for details on installation and running CBMC analysis on TF-RMM sources. ################## Install Clang-tidy ################## Clang-tidy is included in LLVM release package. It can also be installed via package manager : .. code-block:: bash sudo apt-get install clang-tidy Note that the ``RMM_TOOLCHAIN`` needs to be set to `llvm` to run clang-tidy build targets from RMM build system. ########################### Performing an Initial Build ########################### The |RMM| sources can be compiled using multiple CMake options. For detailed instructions on build configurations and examples see :ref:`build_options_examples`. A typical build command for the FVP platform using GCC toolchain is shown below: .. code-block:: bash cmake -DRMM_CONFIG=fvp_defcfg -S ${RMM_SOURCE_DIR} -B ${RMM_BUILD_DIR} cmake --build ${RMM_BUILD_DIR} ############### Running the RMM ############### The |RMM| is part of the CCA software stack and relies on EL3 Firmware to load the binary at boot time appropriately. It needs both EL3 Firmware and Non-Secure Host to be present at runtime for its functionality. The EL3 Firmware must comply to `RMM-EL3 Communication Specification`_ and is typically the `TF-A`_. The Non-Secure Host can be an RME aware hypervisor or an appropriate Test utility running in Non-Secure world which can interact with |RMM| via Realm Management Interface (RMI). Building all of the involved stack is complicated. We recommend using the `Shrinkwrap`_ tooling to bootstrap the stack. For more details on `Shrinkwrap`_ and utilizing configs and overlays included in |RMM| please refer to :ref:`using_shrinkwrap_with_rmm` and, specially for building a demonstrator for 3-world, you can refer to :ref:`3_world_testing`. The |TF-A| documentation also provides some documentation to build |TF-A| and other pieces of firmware for RME in `TF-A RME documentation`_. The |RMM| build option in |TF-A| should point to the ``rmm.img`` binary generated by building |RMM|. If |RMM| is built for the `fake_host` architecture (see :ref:`RMM Fake Host Build`), then the generated `rmm_core.elf` binary can run natively on the Host machine. It does this by emulating parts of the system as described in :ref:`RMM Fake host architecture` design. ----- .. _Arm GNU Toolchain downloads: https://developer.arm.com/downloads/-/arm-gnu-toolchain-downloads .. _LLVM Releases website: https://releases.llvm.org/ .. _RMM-EL3 Communication Specification: https://trustedfirmware-a.readthedocs.io/en/latest/components/rmm-el3-comms-spec.html .. _TF-A: https://www.trustedfirmware.org/projects/tf-a/ .. _TF-A RME documentation: https://trustedfirmware-a.readthedocs.io/en/latest/components/realm-management-extension.html .. _TF-RMM Gerrit page: https://review.trustedfirmware.org/admin/repos/TF-RMM/tf-rmm .. _Git hooks documentation: https://git-scm.com/docs/githooks .. _Shrinkwrap: https://shrinkwrap.docs.arm.com
